HELP PLEASE! Simcard problems/Network problems?
Hi there
I have just bought the Sony Xperia S and have put the simcard in and I cannot get any internet or anything, keeps saying 'your simcard might not be in correctly' I cannot ring anybody either?
Does the simcard need activating? Or can you think of another solution for this? Or is there a problem with 02 at the moment?
Thanks
Message 1 of 5
4 REPLIES 4
By the way the simcard is in correctly as this is the only way it will fit in!
Message 2 of 5
Basically it has a constant red x at the top of where the signal is
Message 3 of 5
it says Sim not provisioned MM#2??
Message 4 of 5
perksie
Level 69: Guiding Light
  • 27018 Posts
  • 247 Topics
  • 1614 Solutions
Answered in your duplicate thread.
To support Disasters Emergency Committee: http://www.dec.org.uk/appeals text Nepal to 70000 to send £5
Sky Unlimited Broadband - Windows 10 - Nexus 4 Android 5.1.1
Message 5 of 5
