FTP using hot spot connection
Hi,
Does anyone know why using the O2 network to use FTP (via a hotspot) will not work to any server? I recently switched to O2 as the network coverage out here in the country was bad on my previous supplier, and we have no broadband available at the house yet.
The connection seems to be eroded by the network filtering/doing something odd with their internal NAT and causing the TLS authentication to fail.  Is there anyone who has encountered the same issue and managed to overcome it?
Thanks, Richard.
Message 1 of 8
7 REPLIES 7
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
Might be something that @Chris_K can help you with?
Message 2 of 8
tyddynonn
Level 1: Joiner
  • 3 Posts
  • 0 Topics
I have exactly the same problem - TLS connections work fine over my vdsl connection (also with O2) but not over 4G. No luck at all with O2 tech support.
And now it's started dropping FTP connections at random....
Anyone any suggestions?
Message 3 of 8
anticpated
Level 30: Meditator
  • 3427 Posts
  • 169 Topics
  • 53 Solutions
Maybe certain ports are blocked and not authorized by default. Generally speaking you would not expect some one to be using ftp over 4g.
Indubitably true. Samsung S21 Ultra and Xiaomi 14 Ultra
Message 4 of 8
tyddynonn
  • 3 Posts
  • 0 Topics
O2 Tech support told me no ports are blocked over 4G - but then, the guy I was talking to didn't know the difference between Active & Passive Mode FTP, so I'm not hopeful.
As to why FTP over 4G - well, when the best vdsl connection you can get is 4.5Mbps and 4G is 20Mbps then it's the only realistic way of supporting a web development process....
Message 5 of 8
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
O2 always say that be we've proved it in the past.
Message 6 of 8
tyddynonn
Level 1: Joiner
  • 3 Posts
  • 0 Topics
Thanks MI5 - how did you prove it to O2?
Message 7 of 8
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
By getting a connection on a different port.
There are some threads on here somewhere from previous testing.
Message 8 of 8
