Android system high usage causing excessive battery drain
Surely some clever person has figured out a better solution to battery drain causes other than turning off utilities. Battery monitor app shows 72% use of android system over five hours causing 40% battery drain and excessive heat. Any advice other than turn off Wifi/Data/GPS/Bluetooth etc would be most welcome. Action taken so far: cleared Cache,factory reset,uninstalled all apps,also using Lean droid app to turn off Wifi, data and Bluetooth when screen is off.Thank you.
Message 1 of 11
1 ACCEPTED SOLUTION
Accepted Solutions
  • 154750 Posts
  • 658 Topics
  • 29443 Solutions
As you have done all that there must be something wrong with the hardware.
If you are still under warranty, put the phone back to stock and contact the manufacturer for a repair or replacement.
The heat and battery drain is been caused by the processor running constantly.
Message 2 of 11
10 REPLIES 10
  • 154750 Posts
  • 658 Topics
  • 29443 Solutions
Message 2 of 11
Cheers, Thanks for the advice, will do.
Message 3 of 11
anticpated
Level 30: Meditator
  • 3427 Posts
  • 169 Topics
  • 53 Solutions
First things first.
Which handset do you have?
Which version of Android do you have?
You can get this in the settings > About Phone > Software Version
Do you have any widgets on the front screen like a weather app or Social Networking things like Twitter, Facebook or similar.
The chances are resetting the handset to tthe factory default will fix whatever is causing the huge CPU spike.
OK, so just re-read your post.
As well the system and application cache, there is also a run-time cache (Dalvik) which should have been reset when you did a factory refresh. So I would also look at your processes to see if there is any dominant system hooks. What's the system idle percentage?
Again it might a build error in the version of Android, so it will be worth investigating if the manufacterer has an update patch. Without knowing much about your handset I can't really help any more than that.
P.S. I am no expert except on occasional weekend.
Indubitably true. Samsung S21 Ultra and Xiaomi 14 Ultra
Message 4 of 11
Toby
  • 11577 Posts
  • 520 Topics
  • 213 Solutions
Let us know how you get on @Anonymous
Thanks for the advice @MI5 .
If anyone finds any other great tips to inhibit high battery drain, do let post them. We could perhaps get a guide together too containing lots of tips if I can find enough tips around the community slight_smile
Get involved:
Message 5 of 11
  • 154750 Posts
  • 658 Topics
  • 29443 Solutions
Turning off all data connections when phone is idling will give any phone a massive boost in battery life, but it inhibits the features available to a smartphone user.
ROM's make a big difference too and some apps that are poorly written will suck the life out of a battery.
There is no "one solution fits all" as every scenario is different, so in order to troubleshoot accurately you need to identify the culprit so it can be isolated.
Message 6 of 11
... Turn your phone off...
Message 7 of 11
  • 154750 Posts
  • 658 Topics
  • 29443 Solutions
My Mother does that.
She only turns the phone on when she wants to use it then turns it off immediately afterwards - Most irritating !!
Message 8 of 11
My mum is the same! She gets £20 credit every two years. Whether she needs it or not, and is using an old nokia I retired in 2004! LOL
Message 9 of 11
  • 98647 Posts
  • 617 Topics
  • 7252 Solutions
Some of us older generation look on mobiles as an irritant....
Message 10 of 11
