Android system high usage causing excessive battery drain
Surely some clever person has figured out a better solution to battery drain causes other than turning off utilities. Battery monitor app shows 72% use of android system over five hours causing 40% battery drain and excessive heat. Any advice other than turn off Wifi/Data/GPS/Bluetooth etc would be most welcome. Action taken so far: cleared Cache,factory reset,uninstalled all apps,also using Lean droid app to turn off Wifi, data and Bluetooth when screen is off.Thank you.
Message 1 of 11
10 REPLIES 10
  • 131310 Posts
  • 838 Topics
  • 7618 Solutions
@jonsie wrote:
Some of us older generation look on mobiles as an irritant....
Oi....some of us like them.......a lot.
Also.. some of us only turn our mobiles off when we get on a plane.... so durrr...Bouncy
Message 11 of 11
