S2stuck ni flight mode after water incident
I have galaxy s2. Dropped it in water, dried out ok overnight. Seems to work BUT  can't get it off flight mode? Any ideas? Maybe it needs unblocking ?
Message 1 of 15
1 ACCEPTED SOLUTION
Accepted Solutions
As above try an let it dry for 3-6 days
Go to settings - accounts - google accounts - sync. Sync any others you have ie drop box an Samsung.
Restart your phone an keep your finger on the volume button so it goes to boot menu, here you can do a system restore. If you haven't damaged anything then it will reset to factory settings an good to go.
Message 6 of 15
14 REPLIES 14
Bambino
Level 86: Prestigious
  • 24641 Posts
  • 1084 Topics
  • 3854 Solutions
If you dropped it in water you can't be certain that your phone definitely dried out okay. The water would have gotten everywhere into places you can't see. You'll most likely have to send it off for repair.
I DO NOT WORK FOR O2
Funniest-Thread-2
Message 2 of 15
perksie
Level 69: Guiding Light
  • 27018 Posts
  • 247 Topics
  • 1614 Solutions
If you tried to switch it on before it was properly dried out, which could take several days, you have more than likely ruined it.
To support Disasters Emergency Committee: http://www.dec.org.uk/appeals text Nepal to 70000 to send £5
Sky Unlimited Broadband - Windows 10 - Nexus 4 Android 5.1.1
Message 3 of 15
F.U.B.A.R.
Message 4 of 15
Personally I would have given it at least three days in the airing cupboard before attempting to switch it on.
I would give it a few more days drying out and then see, if still stuck in flight mode then I would do a factory reset... You might get lucky.
Message 5 of 15
Message 6 of 15
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
What a bizarre post !!
Message 7 of 15
macblank
Level 15: Gaining a Reputation
  • 520 Posts
  • 19 Topics
  • 23 Solutions
having watched the gadget show I know (well according to the old bloke) if u don't rescue it in under 10 seconds and remove the battery IMMEDIATELY it's buggered anyway (sorry to ips and other non removables)
then shake a couple times to get rid of excess water
then put straight into a bowl/tub of rice and leave in a say warm place for a couple days
***I'm not guaranteeing this works***
however this worked on the show as far as I remember
Old Phone Geek!!! A Mobile User Since 1993
Samsung Galaxy S3
Feel Free to Add Kudos, If I Have Helped slight_smile
Message 8 of 15
why may i askk?
i was suggesting to back up then restore from boot to see if that would kick it off flight mode.
i find your post bizarre finding mine bizarre? have you left your pipe somewhere?
are you staff?
Message 9 of 15
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
@Anonymous wrote:
why may i askk?
are you staff?
You advise doing a back up before a factory reset (which will delete the back up you have just done), then you give the incorrect procedure to enter the bootloader on an S2. Adiitional to this, if the phone is water damaged it will have suffered from hardware failures which is most unlikely that a software reset will fix..... Yep, my pipe is missing 😞 Staff !!!! How very dare you wink
Message 10 of 15
