Rapid loss of battery [power
Camellia
Level 1: Joiner
  • 4 Posts
  • 3 Topics
In the last week my 6 year old Samsung galaxy phone has begun to lose power at an alarming rate.
I am sending a few long texts - no more than 3 per day. I don't stream, use e-mail or anything else like that on it and i am confined to home until July so it's not going anywhere. Usually it will lose about 6-10% a day, now it's more like 90%. Have used the setting maintenance button to close off background apps but that doesn't seem to help. My husband thinks the battery's kaput. help please.
Message 1 of 5
1 ACCEPTED SOLUTION
Accepted Solutions
  • 154826 Posts
  • 659 Topics
  • 29444 Solutions
Non removable battery.
Have you rebooted as something may be stuck trying to sync.
Is the top of the phone getting warm?
Have you checked for software updates?
Message 5 of 5
4 REPLIES 4
  • 134692 Posts
  • 847 Topics
@Camellia
Yes a new battery is needed. you can get one from Amazon. What make of Samsung is it  (just to make sure the battery can be removed)?
Message 2 of 5
  • 154826 Posts
  • 659 Topics
  • 29444 Solutions
Have you rebooted the phone recently?
Message 3 of 5
Camellia
  • 4 Posts
  • 3 Topics
Hi Cleoriff
It's a Galaxy S6 Edge bought in Sept 2016.
Doesn't appear to have any way of getting into it to remove a battery, but suppose there must be, for the sim card insertion etc.
Usually get all this done in the local O2 shop - now shut because of lockdown.
Message 4 of 5
  • 154826 Posts
  • 659 Topics
  • 29444 Solutions
Message 5 of 5
