galaxy s4 incoming call volume is very low
galaxy s4 incoming call volume is very low...can anybody help me out ...thanks
Message 1 of 3
2 REPLIES 2
I'm presuming that volume is set to maimum on the handset?
Is there any cover/case etc. that might not have been machined properly blocking the ear piece hole(s)?
Message 2 of 3
Have you tried checking the settings? Click volume button up/down on any page and to the right hand side there will be a settings option. Make sure everything is turned up.
Hope this helps
Message 3 of 3
