Samsung S2 : Battery problems
Can anyone help plz got Samsung S2 , having problems after i've charged the battery fully and taken the plug out , it saying its still charging , any ideas anyone ? doing my head in only just started doing it yesterday , been ok before then
Message 1 of 5
1 ACCEPTED SOLUTION
Accepted Solutions
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
The charge port is either damaged or dirty. Try carefully cleaning out with a toothbrush and blow hard into it. If it's not dirty it will need to go in for repair by changing the charging port. It gets damaged if you don't pull the charger out squarely.
Message 2 of 5
4 REPLIES 4
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
Message 2 of 5
Thankyou i will try that if not its off to the phone hospitall for it Cat Indifferent
Message 3 of 5
i have cleaned the charge port and now the battery is flashing after it has been charged , other forums suggest that alot of Samsung S2 customers are experiencing this problem , any ideas folks ?
Message 4 of 5
Other than what MI5 has said I can see only a few other things to try.
A factory reset especially if you are running a lower firmware than currently available.
A battery calibration ( some say works others do not)
A new battery or if you know somebody that has a the same phone try there battery. ( I would try this first.)
Message 5 of 5
