Help, phone suddenly shut down and won't charge, no way to ring for medical help if I need it
NorthernRealm
Level 1: Joiner
  • 5 Posts
  • 2 Topics
Today my Huawei PSmart just suddenly shut down for no reason and now it won't charge. I only got it in June 2019 from the Carphone Warehouse and it's on a contract with O2.
Do O2 have an email address I can contact them on?
I've checked the repair page and could send it off for repair, but it doesn't actually say how or where. It frequently mentions going into the stores which are now closed. The help pages just send me round in circles and don't answer any of my questions. I don't have a phone to ring them on, so I'm not sure what to do. I do have an old phone I've just charged up, but I remember that it takes a different type of SIM card to the Huawei phone, so I couldn't ring them on that.
Should I order a 'sim only' sim card until my Huawei PSmart phone gets repaired, so that I am able to make calls? I feel very worried because if I get ill I currently have no way of ringing anyone for help during the pandemic.
Message 1 of 4
3 REPLIES 3
  • 155089 Posts
  • 659 Topics
  • 29466 Solutions
You're better off talking to Huawei directly https://consumer.huawei.com/uk/contact-us/
You can use adaptors to change your sim size which would be quicker and easier that getting one off O2 right now,
Message 2 of 4
Bambino
Level 86: Prestigious
  • 24641 Posts
  • 1084 Topics
  • 3854 Solutions
As well as @MI5's suggestion, you can try calling O2 using Skype on 0800 032 1402
https://community.o2.co.uk/t5/Off-Topic/A-Guide-To-Skype/m-p/1305104/highlight/true#M181823
Best time to try to get through is 8 am
Take a look on Amazon for sim card adapters. They're not expensive.
I DO NOT WORK FOR O2
Funniest-Thread-2
Message 3 of 4
NorthernRealm
  • 5 Posts
  • 2 Topics
Thanks both for your help. I've just orded the sim adapters as my new phone has a nano sim and the old phone takes a standard sim from looking at it. My new phone has suddenly switched on whilst plugged in after hours, but I'm not sure it's actually charging. I took the sim card out before it switched on so it's still emergency calls only. I'll keep it plugged in overnight and hope it's charged by tomorrow so I can put the sim card back in. If not I'll hopefully be able to use the sim card in my old phone until I can get this one repaired.
Message 4 of 4
