Galaxy 6Edge+ wifi connection problem
Jaycr
Level 1: Joiner
  • 22 Posts
  • 2 Topics
Hi,I wonder if anyone can help or point me in the right direction with the following problem. I recently changed from a Note 4 to the S6 Edge + and, whilst I like almost everything about the phone I cannot get it to connect to my Home 5g connection. My home wifi has a 2g and 5g connection option and everything else i.e. Tablet, laptop, wife's iphone etc all connect to the 5g option. it's just my S6 which refuses to connect to the 5g but always connects to the 2g option. I cannot be sure but I'm fairly sure it was connecting to the 5g for the first few days I had it and I think it's only the last couple of days where it's reverted to the 2g only. I hope this makes sense to some tech wizard on here and I'd really appreciate any feedback or advice you can give me.
Many thanks, Jim
Message 1 of 10
1 ACCEPTED SOLUTION
Accepted Solutions
  • 93252 Posts
  • 609 Topics
  • 6984 Solutions
My laptops will only pick up the 2.4ghz but it's plenty fast enough at 100+ download. On the phone there is no noticeable differences between the two on speed test.
Message 7 of 10
9 REPLIES 9
  • 93252 Posts
  • 609 Topics
  • 6984 Solutions
Try resetting the router, forgetting the network on the phone and re-enter the password.
Message 2 of 10
Jaycr
Level 1: Joiner
  • 22 Posts
  • 2 Topics
Hi thanks for your reply. Unfortunately I have already tried that but it made no difference. Thanks anyway. Jim
Message 3 of 10
  • 144497 Posts
  • 634 Topics
  • 27704 Solutions
I'm not sure what you mean by a 2g and 5g connection?
Currently using:
Pixel 7a (O2 & Lyca), One Plus 6 (Sfr), iPhone 12 Pro Max (Vodafone)
Message 4 of 10
  • 93252 Posts
  • 609 Topics
  • 6984 Solutions
I have 2 and 5 showing up at home on my virginmedia wifi selection. I always connect to 5 but tbh there is no real difference.
Message 5 of 10
  • 144497 Posts
  • 634 Topics
  • 27704 Solutions
If we are talking ghz it's either 5 or 2.4 ghz, hence my confusion.
2.4ghz is the most common standard and the one to go for.
Currently using:
Message 6 of 10
  • 93252 Posts
  • 609 Topics
  • 6984 Solutions
Message 7 of 10
  • 144497 Posts
  • 634 Topics
  • 27704 Solutions
Yeah a lot of equipment won't work with 5ghz in the UK and it won't make any difference to speed at all.
2.4ghz will also travel further so the range is much better too.
Currently using:
Message 8 of 10
Jaycr
Level 1: Joiner
  • 22 Posts
  • 2 Topics
Ah okay so nothing to worry about. Many thanks for your responses. Much appreciated. Jim
Message 9 of 10
  • 144497 Posts
  • 634 Topics
  • 27704 Solutions
No worries Jim.
Currently using:
Message 10 of 10
