on 13-09-2021 11:32
I ordered a new phone and contract with o2 last week and everything went well but nothing has arrived and can’t find any number to ring for help and the online chat is forever busy great start to the service!
Solved! Go to Solution.
on 13-09-2021 11:38
You need to contact O2.
All numbers are in this guide Guide: Coronavirus Community Help and Support
When you call, you will be asked for the reason you are calling.
Stay silent for 15 seconds and you will be taken to the keypad options.
Press 2 for Everything Else
Press 5 for More Options
Press 7 for Anything Else which will put you though to someone.
You can also try saying "Upgrade" or "Fraud" to be connected to an advisor.
8.00am is the best time to call if you can.
on 13-09-2021 11:38
