Sony Z1 Compact help - calls cutting out after 10seconds
I have had my z1 compact for about a month and now for about a week everytime I make or recieve a call just goes silent the person cant hear me and I cant hear them, the phone hasnt hung up it acts as if it is still on the phone
Its not the signal or other persons phone as its happened in various places/people.
Any ideas before I take it back to the shop?Help
Message 1 of 18
17 REPLIES 17
okay thanks
Message 11 of 18
  • 154746 Posts
  • 658 Topics
  • 29443 Solutions
I'm struggling too tbh.
The only place I can find reference to proximity sensor is in the service menu and mine is "off".
Check by dialing *#*#7378423#*#*
Message 12 of 18
I did have a look also and mainly come across lots of forums with people all having issues with the sensor.
I'd go with contacting the manufacturer.
Message 13 of 18
I had a look as well and could only find mine in the service menus. Mine is also set to "off".
Message 14 of 18
clarkeshire
Level 1: Joiner
  • 1 Posts
  • 0 Topics
I've just got this handset for my wife and it is behaving exactly the same way. It's literally a week old.
When making a call the audio stops (bbth ways) after about 10seconds. When receiving a call the audio cuts out (both ways) after about 10 seconds.
Switching to handsfree gets the audio back again, but it cuts out after a further 10s. I'd guess there's a software issue here.
I've just rebooting the phone and that's cured the issue, I wonder how long for....
Message 15 of 18
I'd be swapping it out before the cooling off period ends which is 14 days from O2.
Message 16 of 18
Gonna have to take it into shop tomorrow, thanks for all help!
Message 17 of 18
Hi ,
Most probably the best move.
A person under 14 days ownership should insist on a replacement not a repair.
As you have owned this a month if they cannot rectify this in-store you will be asked to surrender the phone for repair. At this point your decision would be to let them have it or seek redress through the manufacturer.
would go with the latter.
Let us know how you get on.
Take care.
Message 18 of 18
