Samsung Galaxy S2 not charging via wall charger or usb port
I have tried both but the battery is dead and have been charging for almost 2 hours now. Phone will run perfectly with the charger in but get no warning that the battery is low unlike any other time, which is unusual. The software is up to date. Help?
Message 1 of 3
1 ACCEPTED SOLUTION
Accepted Solutions
Hi,
If all else fails seek assistance from Samsung Uk support.
http://www.samsung.com/uk/support/main/supportMain.do
Hope all goes ok for you.
Message 3 of 3
2 REPLIES 2
  • 154643 Posts
  • 658 Topics
  • 29438 Solutions
It's either a dead battery or a damaged/dirty charging port. Try a different battery first and check the charge port (carefully) for fluff.
Message 2 of 3
Hi,
Message 3 of 3
